PCB building
chopnhack
Apr 28, 2014
1,576
Agreed, that board looks perfect, good job - just need to tin it now ;-)
chopnhack
Apr 28, 2014
1,576
Don't use sandpaper - I have found that it scores too deeply - try steel wool instead - much better surface. Deep scores produced with sandpaper alter etching in my opinion.
HellasTechn
Apr 14, 2013
1,579
I know.
The one i use is not simple sandpaper. It is special for use with metal and i work it with soap water. I dont know how you call it in english.
I will try steel wool next time, Thanks.
chopnhack
Apr 28, 2014
1,576
I know.
Its wet sandpaper, typically black in color and has very fine grit - 400 to 1000 grit is common and is used often for rubbing down finishes in woodworking as well as in auto body work. I still don't use it for pcb's because we exert uneven pressure when sanding by hand and cut through too deeply in spots. Even when using a sanding block, I have found the edges end up getting knocked down first while the center needs more work. Steel wool for me only.
HellasTechn
Apr 14, 2013
1,579
Here is the board finished !
Sadlercomfort
Ash
Feb 9, 2013
424
The other two pictures have only just popped up. Looks amazing =) the tinned copper looks really professional
HellasTechn
Apr 14, 2013
1,579
Well i wouldn't say professional... but it is O.K.
This board will last long trust me. We will probably not be around to see it failing, if you know what i mean ;)
Sadlercomfort
Ash
Feb 9, 2013
424
Can't complain with that ;) you should give yourself credit, it's easy to criticise your own work. It's hand made but it doesn't get much better than that.
HellasTechn
Apr 14, 2013
1,579
Well, like i said, it is OK for hand made. It can not be compared with a machine made though.
It's just that for small projects like the ones we do, a better PCB would be an overkill.
HellasTechn
Apr 14, 2013
1,579
One more Board.
chopnhack
Apr 28, 2014
1,576
Came out great Constantine! Was it your design also? What is it for?
HellasTechn
Apr 14, 2013
1,579
This is my latest board. I tined it by hand with a flat tip soldering iron and 60/40 solder wire. :)
