- Joined
- Feb 9, 2013
- Messages
- 424
Here is the new board i made to replace the last one
Looks good Constantine!
I am waiting for the tinning material to arrivejust need to tin it now ;-)
I know.Don't use sandpaper - I have found that it scores too deeply
Its wet sandpaper, typically black in color and has very fine grit - 400 to 1000 grit is common and is used often for rubbing down finishes in woodworking as well as in auto body work. I still don't use it for pcb's because we exert uneven pressure when sanding by hand and cut through too deeply in spots. Even when using a sanding block, I have found the edges end up getting knocked down first while the center needs more work. Steel wool for me only.I know.
The one i use is not simple sandpaper. It is special for use with metal and i work it with soap water. I dont know how you call it in english.
I will try steel wool next time, Thanks.
Yes that's the one.ts wet sandpaper, typically black in color and has very fine grit - 400 to 1000 grit is common and is used often for rubbing down finishes in woodworking as well as in auto body work.
I will try it on my next boardSteel wool for me only.
Here is the board finished !
Well i wouldn't say professional... but it is O.K.
This board will last long trust me. We will probably not be around to see it failing, if you know what i mean![]()
