I have started a new thread because this has me stumped and the outcome will be good advice for all.
I have wired two, 2.2kw 230vac dust extraction motors to a box containing several SSRs being 24-380VAC 80A with 3-32vdc trigger.
The dust extractors came from the same factory.
One extractor has just two wires coming out of the motor and is a double capacitor motor. All the internals allowed me to just put a SSR in series with the phase which works great. I did need to up the rating of the SSRs to 80A as the 40A ones were too small for the initial rush of current and/or were rated incorrectly.
The second dust extractor has two wires coming out of the motor and two wires coming from a single start capacitor. This one was controlled by a KJD17 switch. I wired it with the start capacitor in parallel with the 230vac input thinking that was correct as per my picture. But no. Boom. I blow my workshop fuse. After looking at the switch, I think I need to wire the start capacitor in line with the phase to bump the input to get it spinning. Not sure. Am about to try???
I would really like to hear from someone who has worked with one of these before. There is no centrifugal switch in the motor. Just two red wires coming out and two white that go straight to the cap.
This system is huge. I have completed everything and am about to commission it. I have fully automated my workshop. Now when I switch on any machine (one out of eight):
1. The machine starts.
2. The extractor starts.
3. The corresponding pneumatic controlled 100mm pipe gate opens allowing dust to enter the extractor.
When I turn off the machine:
1. The machine stops immediately.
2. The extractor continues to run for 30 seconds then stops. I have built a simple delay switch with a cap, two diodes, a resistor, npn transistor and small relay. The capacitor determines the length of delay along with the resistor. I can post this circuit if anyone wants to see.
3. The pneumatic 100mm gate from the machine shuts.
I am very proud of this massive project and plan to show it off in a post with pictures. I have worked out I will save at least 40 hours a year. At least!
But keen to hear about this single phase motor issue I am having?
