Ritesh Narayan
- Jan 8, 2017
- 7
- Joined
- Jan 8, 2017
- Messages
- 7
Hi All,
I am working on a electric curtain or electric blind project at home and I am a bit stuck.
I would like the curtain to operate a 12V motor drive with a single Push Button switch (not a toggle switch)
I would like it to behave as follows:
1st press: forward
2nd press: stop
3rd press: reverse
4th press: stop
THEN START CYCLE AGAIN
Of course if it is at one limit then their will be only one direction to go.
I have done a partial design in the below diagram (shown in driving forward state), but it doesn't work exactly as I want it to:
I have a limit switch [L] mechanically built in to the motor drive, that is toggled every time the curtain reaches either extreme.
This is where the design has a problem:
At the moment, I have a normally open push button switch [C] to control the curtain drive.
This allows the drive to move forward.
I have another normally closed push button switch [O] which will stop the drive at any point.
In this design, the curtain can only be reversed once it reaches the closed limit, where the limit switch [L] is toggled.
At this point push button switch [O] needs to be pushed (sort of a reset) and then push button [C] will again allow the drive to commence in the reverse direction.
Again, once reversed to the limit, push button switch [O] needs to be pressed before [C] will allow for forward drive again.
I would like switch [O] and [C] to be replaced with a single push button to allow it to behave as described initially.
Also I as below I would like to keep the circuit as simplistic as possible, hence the use of the relays in my first design.
Your guidance is much appreciated.
1st press: forward
2nd press: stop
3rd press: reverse
4th press: stop
