Circuit Which Turn On The Light As A Response To A Specific Sound Sequence ?
akshay797
Jan 30, 2017
5
I want to make a simple circuit which turns on the light when hearing a specific sound sequence .. for example : a beep sound -second gap-another beep sound .
please suggst a simple circuit with out the help of voice recognitio
CDRIVE
May 8, 2012
4,960
Welcome to EP. The most practical approach would be a microcontroller.
Chris
akshay797
Jan 30, 2017
5
Chris
thanks for the response .. can u be more specific about the micro controller and whole setup ? i just want the circuit to respond to the sound sequence which is based on a time-gap?
CDRIVE
May 8, 2012
4,960
What's going to generate the beep sound?
Chris
BobK
Jan 5, 2010
7,682
The difficulty of this project will depend a lot on the loudness of the triggering sound vs the ambient noise. It could be as simple as a bandpass filter, peak detector and a little bit of logic, or as complicated as a DSP (digital signal processor) doing an FFT (fast Fourier transform) to analyze the sound.
Bob
akshay797
Jan 30, 2017
5
Bob
hey ... This is my whole project .. I am making a plug point with a small circuit , An app in the smartphone produce sound like i mentions above .. so when hearing the sound the circuit should respond ... the loudness of the sound is normal audio level of a smart phone speakers .. also the chances for additional background noises are less .. so a solution ???
KMoffett
Jan 21, 2009
723
Is the beep a fixed frequency tone, or more like a buzzer with lots of harmonics?
Ken
FuZZ1L0G1C
Mar 25, 2014
366
Similar circuits mostly use a condensor mic / preamp filtered by active feedback-loop type notch or narrow-bandpass filters, some with frequency band-pass tuning.
The key-finder keyring-fob is probably the audio-sensor part of what you need.
Except these use a monolithic I.C. covered by a black blob of epoxy - not traceable.
Drives an oscillator to return a 'beep' to a human whistle and most other KHz frequencies).
The commercial "hand-clap" switches work on the timing principle you need.
If you clap once, nothing happens. Clap twice within about 0.5 sec, and the circuit activates a relay.
I opened mine to see "what makes it tick".
My hand-drawn traced circuit unfortunately got damaged / discarded, but remember it used a c/mic then 741 op-amp as part of filter, to various logic IC's (forgot which since then). Switch now buried in storage..
A hand-clap is white/pink noise analyzed at fpeaks about 11.5-13 KHz.
Your CCT will likely fall into the lower audio range of about 500 - 5 KHz (My smartphone's peak is 2.2 KHz).
I'll dive into my old magazine-storage boxes, as I plan a very similar project to wirelessly extend top-loader 2-tone beep* from bathroom to lounge via mini FM tx. Then a relay / S.C.R / Triac for small lounge-mounted lamp.
*(Pre-rinse pause, waits for fabric-softener, beeping, then after 'X' seconds idle, continues "softener-less").
W/M alarm-tone beeps about** 1875 Hz, 2342 Hz, pause, repeat.
**From memory recall.
Audioguru
Sep 24, 2016
3,656
I think your beep, beep detector will also detect my dog (bark, bark) and my wife (DINner's REAdy).
My daughter bought a keys finder and hand-clap switch that activated so often that their batteries lasted only for a few days.
