From a newbie: I would like to know the maximum amps that most car radio's use. The radio I'm working with is a Pioneer KEH-1300. Any help would appreciated.
yeah the radio is a Pioneer KEH-1300 I also tried looking for specs, all I know is that, of course, the system runs on 12volts times ??amps = ??wattsit will depend on the wattage rating of the system, efficiency of the system etc
I can find no info online for the Pioneer KEH-1300 .... sure you typed that correctly ?
being a newbie I don't know what you mean by "watts per channel"so does it have a watts per channel on a label on the unit ?
the radio literally has no specs whatsoever except for the brand name and series
the vid contains additional questionsyou answered my main question I was half hoping I could use an old 3.25A 12V power supply I have
yeah that's what I thoughtAt very low volume levels that power supply might work, but you'd want to be VERY careful not to overload it.
which one would the antenna or is there an antana.
Sir Ben King. . . . . . . .
With what you have shown us, looks like you are in luck, since this unit goes back to the 90’s and you did not show the presence of the deluxe, SEPARATE Power amplifier pack.
Therefore . . . it must not have been pulled from an ‘ole Catarack, Rincon Contirental or Mercy-days.
I have given you snippets of the connections of the foil side of the PCB proper which you were running your fingers over.
The proper plug and wiring harness which would have been used on the unit.
With the third part . . . being the concerned section of the schematic.
So it looks like the use of 7 “wars” connected to the unit, along with an antenna, might have that lil’ puppy yelping again . . .with glee.
RED for power
BLACK for ground
PINK for constant power for electronics u/p memory retention
4 wires being used for the Front Left and Right speakers.
IF this is NOT just someone’s cast away non-working radio.
Query me if there is something not understood and also explain your planned operation . . . to catch you prior to possibly making any boo-boo’s.
UNITS TECHNO REFERENCING:
http://i.imgur.com/PWDSbRA.png
73s de Edd
