Help with A123 transistor.
HellasTechn
Apr 14, 2013
1,579
HellasTechn
Apr 14, 2013
1,579
Thank you for the information !
I only have one doubt about the 2SA. becase of it's package. Like in the attached picture the one i have is TO-92.
The 2sa123 and nte126 are TO-18
Minder
Apr 24, 2015
3,561
In that application I would not expect it to be that critical, most likely any close PNP would suffice.
M.
HellasTechn
Apr 14, 2013
1,579
You are right. My problem is that i am not sure if this damaged A123 is the same as the 2sa123. What troubles me is that i dont know its pin arrangement and even if it is a PNP indeed or not.
It's probably the same but i just want to make sure...
HellasTechn
Apr 14, 2013
1,579
that still does not solve my pin arrangement issue. Say i replace it with a close PNP like minder suggested, how can i be sure which pin is base, collector and emmiter since my part is TO-92 (not a TO-18)?
Minder
Apr 24, 2015
3,561
Legend toward you, pins down, left to right, e,b,c.
M.
Minder
Apr 24, 2015
3,561
I have a post into a supplier for original pin out clarification.
M.
Minder
Apr 24, 2015
3,561
A voltage measurement of the original transistor connection should confirm it, preferably with the old one removed.
M.
HellasTechn
Apr 14, 2013
1,579
M.
There is no legend on the pcb indicating e,b,c positions, it only shows the shape of the component (flat side , round side).
***It just crossed my mind that i do have a few C123 transistors in my hand. Any chance that they could be complementary and have same e,b,c arrangement ?***
M.
I cant do that because i only have the PCB not the whole refrigerator.
have a reference with e other variations but not that one
Yes, but still not sure that can help.
M.
That would be the best. For now it looks like i am stuck. i will order a new one from e-bay, since i see no other option, and i will measure it when i get it. Meanwhile if you find anything please drop a line !
Thank you both !!!
Minder
Apr 24, 2015
3,561
If you can identify the power planes + and -, then a resistance check to each from the 3 pins should point to it, with a PNP the emitter will be towards the +ve rail.
and collector to the -ve.
The base somewhere in between.
Nothing back yet.
M.
HellasTechn
Apr 14, 2013
1,579
ok when faceing the flat (printed) side of the a123, its right-hand pin is connected to an sn74hc14n pin 14 which is VCC pin. so that i guess is the emitter ? then middle = base and left = collector ?
HellasTechn
Apr 14, 2013
1,579
CORRECTION the pin connected to VCC is the left hand pin...
its middle pin goes to pin 7 (GROUND PIN) of the same ic through a potentiometers middle (wiper) pin.
the right hand pin goes to the IC's pin 12 (marked 6y on the datasheet) pin 12 must be an inverted output
Minder
Apr 24, 2015
3,561
What data sheet?, for the I.C.?
Anything else connected to the IC Pin12?
If the IC was open collector output, the Tr collector could also be connected in parallel.
Left appears to be emitter.
M.
