Hi all,
Here's my issue the fairy lights we purchased (4 sets of) are great, but they come with a solar panel that has a multi-fiction switch and when the juice runs out of the panel the lights revert back to the default sequence instead of staying on the chosen function.
Im hoping that there might be an easy way around this, please see circuit board pictures.
There is also room for two more batteries if I place in connections for them, would this also be an option?
The current single battery is a Ni-Mh 1.2V 1200mAh
The power input from the battery to the board is as follows: Battery positive (red) to B+ on the board, Battery Negative is connected to Solar Negative (Black) and then S- on the board. The Solar Positive (white) goes from the Solar Panel Positive to the S+ on the board.
The rear of the multi-function switch is the two rows of 3 pins (one set is soldered together, the other 3 are separate)
Thanks in advance.
Thanks in advance.
