24v battery charger unit, rectifier output 36v at no load. Can l connect to battery?
that would be a bit high. the loaded voltage needs to drop to around 25-26V for correct charging
I don't think 36V would drop that far
what sort of battery ?
rectifier output 33.9 vDC at no load,
Where is the problem?
A 24v battery charger will charge at about 28v.
Connect the charger to the batteries and check the voltage. If possible also connect an ammeter to check the charge current.
