How can fix 24v /80amps battery charger voltage drop while connect load-pls help
hareeshkp
Jan 27, 2021
I have battery 24v/80 amps battery charger but only its can give 8amps .if we connect more load voltage drops to 12 volt.pls help me to fix this problem
Alec_t
Jul 7, 2015
3,821
Welcome to EP!
Can you post a link to the charger's specification/datasheet/advert?
HellasTechn
Apr 14, 2013
1,579
Welcome.
Are you sure that the the fault lies within the charger itself ?
Could it be that the battery you want to charge does not need more than 8 Amps ? That could happen if the battery is partialy discharged. In other words the battery may not be discharged to the point that will require more than 8 Amps.
Many batteries, depending on the type etc, will draw less curent while their voltage is rising during a charge cycle.
I am not sure about the voltage droping to 12V on the charger
