Sir zgaja . . . .
OK then at that time I did not know if a power supply was involved or not . . . . since it seems to be just the adsl rj45
aspect of the unit . . .and the incoming line is probably fine.
BUT have you run in a lap top and checked out that line.
If all is well then, the RV201 should have covered any high fast spike input supression . . . and I don't see it exploded or having the glasss fractured. There is also additional protection being provided by a set of diodes on the T and R lines . . . they are located just to the right and left of the LAL2009 input transforner symbolization marking..
They probably will ohm out as the value of the windings that they are shunting, unless they have crunched and failed co9mpletely down to a dead short.
If all tests out up to this point, the simplest next test will be the plugging in of the DSL line and use of an oscilloscope for the scoping of the just described junctions for digital activity. OR, if having none yourself, you need a techno-friend that has a scope that can do that test.
73's de Edd
