seanspotatobusiness
- Sep 11, 2012
- 193
- Joined
- Sep 11, 2012
- Messages
- 193
I have a circuit I made for an experiment with four LEDs in series behind a transistor with a floating base so the circuit is open and LEDs are unlit. When I measured the voltage across the LEDs I got a stable value of about 2.4 V but when I measure the voltage across the collector and emittter I get 2.1 V most of the time with a brief increase to about 12.4 V every second; I don't have access to an oscilloscope right now so I can't tell exactly what is happening. When I measure the voltage across the LEDs and the transistor, I get a constant 8 V which is as expected (I have my bench power supply set to provide 8 V). What is happening?
The reason for me doing this is because I want to use a transistor to turn on and off 50-60V LED filaments (which are a bunch of about 20 LEDs in series) and I was hoping I could use the BC337 transistor to do this. The maximum rated voltage across the collector and emitter of the BC337 is 45 V but I was thinking that even when the transistor is off, maybe the LED filament would drop some of the voltage so the transistor would never experience too much but this weird behaviour with brief pulses of at least 12.4 V makes me question that.
The floating base was at -0.6 V so maybe grounding it will change the behaviour?
