If the outputs are DC and are completely separate (not each one grounded to earth) then simply connect the + of one of them to the - of the other to get 31V. Why do you need diodes?Hi,
Can I connect a 19 v and a 12v supply in series. What should I take care about if it can be done. Also please advice on the type of diodes and diode name I have to use. A connection diagram would be appreciated.
Placing diodes across the power supplies is also a very good idea when placing them in series.
If you short out the combined supplies, it prevents one power supply from driving the other with reverse polarity.
If you connect two power supplies in series, then short the output, it is like connecting two power supplies together positive to negative and negative to positive.
This is worse than simply shorting the power supplies. In this case, rather than the positive rail being forced to ground, it is forced below ground. For a very simple series regulator this can defeat a current limit.
Placing reverse biased diodes across the outputs means that in the worst case, the positive output can only go a diode drop below ground. This will typically allow even a simple shunt regulator to limit the output current.
If the power supplies are exactly the same type (same voltage, amperage, etc.) and make does it need diode protection. What if both are the same model laptop chargers?
