Richard9025
- May 24, 2016
- 205
- Joined
- May 24, 2016
- Messages
- 205
Hi!
I'm having some problems after I replaced all the electrolytics in this radio.
The unit in question:
The unit disassembled:
This thread is only about the amplifier, so I won't get into presenting how it works only if necessary (the rotary tv-like tuner, VHF block, cassette-radio switch and tape mechanism)
When I got it, the amplifier worked ok, it wasn't amplifying the sound as loud as my other radios and at high volume (over 70%) it would start to distort the sound.
After I changed all the electrolytics, the radio got 5x louder, so loud that I can't get to 100% because I fear that the speaker might get destroyed. But also something got 5x bigger, the distortion.
If I turn the volume over 25%, it starts distorting very badly, and the speaker transforms into a trampoline, if I put a tic tac or just a piece of paper, it throws it out like a spaceship (remember, this is at 20%, at 100% is 4x worse), not to mention that it moves on the table and it vibrates like hell, it clearly isn't made to work like this.
The unit is a very low hour set, it looks exceptional and hasn't been tampered with (the paint was still on the screws when I opened it), even the original bulbs are working.
Photos with the speaker (not a single hole in the membrane).
Before talking about the electronic circuitry, I want you to hear how bad this unit sounds at a high volume:
at 10%
https://vocaroo.com/i/s028kagZ5hHv
at 25%
https://vocaroo.com/i/s1ZKRCu4U8fB
at 50%
https://vocaroo.com/i/s1fVolpiXJRF
and a perfectly sounding radio receiver from the same time (just to compare the two):
at 50%
https://vocaroo.com/i/s1JYxMIg4Pu6
at 100% (extremely loud, notice how the distortion is very small unlike the unit I'm repairing)
https://vocaroo.com/i/s1PlVjZ5beRo
Now the electronic part, remember that I replaced every electrolytic cap in this radio.
The schematic:
What I did is: I measured the voltages and the transistor junctions:
I hooked the radio to a battery that measured exactly 9V, In-circuit it measures 8,62V that means that 0,4V are lost by the internal resistance of the battery.
The voltages seem fine to me (all are 0,4v lower because 8,62V enter the circuit, not 9V like in the schematic)
THE TRANSISTORS ARE MEASURED IN-CIRCUIT!!!
Also, the transistors look ok, remember, this is a very low hour set.
One thing that I did is I got the amplified audio (at 5-10% volume) and fed it to the phono input of another radio and it sounded very very good, maybe the speaker is shot. I'll hook it to another speaker to see if it does any better, maybe the amp is good.
I had another unit, the exact same model, but I trashed it for parts because it was very low quality and too far gone. I still have the parts, so if I need to replace something, it won't be a problem.
So, the problem may be:
1. an amplifier problem (transistors over-amplify the signal or one transistor distorts the sound then that sound is amplified or some other problem inside the circuitry)
2. a speaker problem (very low impedance leads to an amplified sound to overdrive it).
3. another problem
The problem can't be the detected signal because I hooked it to another amplifier and it was crystal clear.
The amp (it includes the tape preamp and record circuitry on the same PCB)
The old removed caps:
Many thanks!
at 10%
at 25%
at 50%
at 50%
The schematic:
3. another problem
Many thanks!
