At this point, all I can tell you is that unless you have a common ground, your voltage divider scheme won't work. And if you have a common ground the series connection won't work.
Perhaps you need to describe exactly what you want to do so we can suggest how you can do it rather than you chase two mutually incompatible ideas in separate threads.
Why do you need to separate the batteries?
I fugured this much (it wont work). Thats why its such a problem. I need to seprate the batteries, so I can charge them separately with 2 charges. In this block diagram I explain the problem well. Also the comparator circuit picture for 2 batteries is uploaded. I have the same problem on it. The switch will separate the batteries and connect them in series. But this will affect the dividers of the comparator circuits?
There will be no ground! The bottom battery's "-" can be taken as ground.
