FuZZ1L0G1C
- Mar 25, 2014
- 366
- Joined
- Mar 25, 2014
- Messages
- 366
Hi all at EP.
Foreword:
I'm planning to design a "System Ready" beeper for my PC at home.
The reason is that it takes a frustrating 6-7 minutes from power-up to boot, load OS and do AV & Sys checks.
After about 7 minutes maximum the activity drops to normal.
Instead of waiting at the PC an audible beep would be better.
The OS beeps via soundcard when it loads <BIOS about 1 minute>, but continues checks another 5-6 minutes.
Proposed idea:
When PWR button is pressed, the <5 volt?> temporary pulse is buffered to feed the trigger of a 555 as a 5-7 second monostable countdown timer.
When set time elapses, a second monostable will enable an astable oscillator for 'X' set seconds to sound a 5 V buzzer / small speaker.
Now the Questions Part:
What is the typical current capacity of a typical tower system with a 500 W PSU?
The sticker states several Amps at 5 VDC but I suspect that the button is via digital circuitry, not 5 V PSU directly.
IE: will buffering the extra circuit likely create havoc?
The actual circuit will be designed as free time allows.
Looking forward to suggestions....
Thanks, Clive ("@
FUzZ1L0G1C").
Foreword:
Proposed idea:
Thanks, Clive ("@
