Accuracy Component Tester.
caps
Jul 29, 2018
183
Hi all
Who was interested in what the measurement accuracy in the transistor tester?
In my opinion, it’s not very bad,at about 1%.
caps
Jul 29, 2018
183
Resistor 1 Ohm 1%.
caps
Jul 29, 2018
183
0,1 Ohm 1%.
ratstar
Aug 20, 2018
485
1% error sounds really great until your talking about pico amps, then its 0.00001% accuracy required i think.
Why? My picoammeter is around a couple of percent accurate. It works fine.
I think you misunderstand what accuracy means.
BobK
Jan 5, 2010
7,682
Um... A 0.1Ω resistor read as 0.11Ω is off by 10%. To be 1% it would have to be between 0.099 and 0.101.
The error has to be calculated as a percentage of the correct value.
Bob
caps
Jul 29, 2018
183
Precision resistor 0,01 Ohm 1%.
BobK
Jan 5, 2010
7,682
In order to measure 0,101Ohm, it lacks resolution.
You cannot have more accuracy than you have resolution. But the reverse is not true.
In your 0.01 example, if it can only display the 1/100 digit, the true measurement might be anywhere from 0.0005 to 0.015 and it would display 0.01. So the precision is about 50%
Bob
Ratch
Mar 10, 2013
1,102
Hi all
What parameter of the transistor is the transistor tester measuring?
Ratch
Don't think so. The resistance of a semiconductor varies with the voltage of the ohmmeter. It does not follow Ohm's law
Exactly.
We haven't seen any measurements you'd typically associate with a transistor.
But I know these devices do them.
Of what they test, I'm not sure you need any particular level of accuracy. Even if you want to find closely matched devices, all you need is something which produces repeatable (and possibly reasonably precise) results, not necessarily highly accurate ones.
kellys_eye
Jun 25, 2010
6,512
Personally I'd use a resistance meter to test a resistor and leave 'that' particular test device for what it was originally intended - semiconductors.
Ratch
Mar 10, 2013
1,102
The OP wrote "transistor tester". Perhaps he meant transistorized tester (ohmmeter).
Ratch
Ratch
Mar 10, 2013
1,102
Exactly.
Too bad this testor is not manufactured anymore. It did a quick check on a transistor by determining if it could invert a pulse. http://www.cbtricks.com/miscellaneo...ore_tf26_cricket_full_sm_with_corrections.pdf
Ratch
kellys_eye
Jun 25, 2010
6,512
Ratch
Nope, the screen (LCD) display is that of one of those cheapo Chinese 'multi-tester' devices.
Hopup
Jul 5, 2015
253
I myself have one of these cheap meters and it is pretty useful, have not used it for transistors other than initial testing of the device. They should be able to detect Hfe, Ube and other parameters, but if I remember right, the results were not very good.
caps
Jul 29, 2018
183
Precision resistance.
1,8к 1%.
3,16к 0,1%.
