What exactly is the difference between these two omron relays?
I would recommend that if you have a pcb that you spray it with some sort of conformal coating on both sides. Dust and moisture can create conductive paths. Even spraying it with a clear acrylic may be sufficient.
That seems reasonable.
tedstruk
Jan 7, 2012
476
Faruksaid-
I found so many models of the basic 12V omron relay in arrow that it is making me totally confused. Can someone clarify why omron has different model of the same specification relays?
no, but if you are trying to switch signal, you should be using a thyristor, in a circuit with a small relay, rather than a power circuit with a solenoid.
Total nonsense
