Beginner question : 555 timer pin 4
RhythMick
Nov 7, 2018
30
And talk about being a newbie... I just discovered stripboard ! I've been drilling 1mm holes in epoxy board and failing to line up the holes properly. Sigh... Feel like a right numpty...
Stripboard and Fritzing : that's quite a combination... they have the bridge rectifier part I'm using so I just left space.
Audioguru
Sep 24, 2016
3,656
Why does your stripboard use wires parallel with strips?? Then you cut those strips where they should not be cut.
RhythMick
Nov 7, 2018
30
You're referring to the first orange wire I assume. Yes it's a little harder to follow when you only have the picture. The trimmer wiper feeds directly into pin 3 (1IN+), so I have to cut the rows above and below that.
I'm not denying there may be better configurations friend, I'm just a beginner at this.
RhythMick
Nov 7, 2018
30
Actually I realise that my question has been answered and this is turning more into a project log. I'll create a new one and consider this question closed. STEVE - thanks a million for your help buddy.
