I was under the impression that 3 phase lines were run most everywhere and the transformers on the poles take 2 of the phases and convert them to 220V center tapped single phase for residential use.
Bob
I'm guessing you part: around $5K for a small 400A service , if they will go that small.
Then of course there's the monthly minimum use fee.
You can buy many VDF's, Static, and rotary converters for that kind of money.
You may want to rethink buying that new car.
Your local utility will need to add 3 transformers to step down the primary line voltage to what you need..
Either way, it runs to the high 4 figures.
Petkan:Ok, I found the following schematic. It seems fairly straight-forward.
What I'm not clear on is how to hook up the 230 VAC at the input of the bridge. This schematic appears to assume a single-line 230 volt 1 phase. But what I would like to do is use a standard residence 220 VAC. That comes in as two 110 VAC lines that are of opposite phase with respect to a common neutral. Is that right?
I don't know how to hook that up at the input of the bridge to get the 220 VDC at the output. Would I hook up a 110v line to the switch and the other 110v line to where it says 230 volts on the schematic? And if so then what about the neural line?
I guess what I'm really asking is how to build a 220 VDC power supply using a standard residence electric service. Once I get a suitable 220 VDC power supply the rest of the schematic is pretty simple. Most of the magic will be in the PWM programmed into the MCU. That part I know how to do.
. All motor drives ultimately work from HV dc bus.
I agree but price aside, It's likely you can't get 3 phase service anyway.Why pay thousands when $300 will solve the problem?
In fact, the most economical solution would be to just convert the machines over to 110v.
and a 3 ph delta(4 wire) feed is usually denied by either the utility company or your local authority.
Yes. It does exist here in residential applications but it is rare.Really? I just asked and paid the money.
but if you have 120v household it gets a little unconventional
