evolandlupiz`
- Apr 14, 2019
- 7
- Joined
- Apr 14, 2019
- Messages
- 7
i've got a small project going on at home for hooking up my car amplifier and subwoofers in my room. i'd like to ask for a bit of help in making sure my circuit will be okay and a bit of help in making sure i get the right power to the system. what power source in my at home area would you recommend, and can you check to see i've got the correct equipment?
for the power source i was thinking of an `adc convert 3000 watts`, thoughts?
this is what i'm using:
(1) x2 subwoofers xfire xfr 12" (*specs below)
(2) x1 amplifier 2400 watts memphis srx 1200d.1
(3) x1 ren20kit 4 guage
(4) x1 bass knob
(5) x1 remote switch to turn on amp
* * * SUBWOOFER SPECIFICATIONS * * *
XFR12.44 12” dual 4Ω Subwoofer
GENERAL
SIZE 12" SUBWOOFER
Voice Coil DUAL
DC Resistance (Ω) Dual 4 ohm (Ω)
Peak Power (Watts) 2250W
Continuous Power (RMS) 750W
Sensitivity 90dB
Effective Frequency Range 26Hz - 150Hz
Cone Material Kevlar Woven Reinforced
Surround Material Precision Linear Drive dual stitched resin fiber
X-MAX 33MM 1 Way
link: link to xfire item on ebay
* * * AMPLIFIER SPECIFICATIONS * * *
Mono subwoofer amplifierPeak Power 1,200 watts RMS x 1 at 1 ohm750 watts RMS x 1 at 2 ohms400 watts RMS x 1 at 4 ohmsClass D amplifier technologyVariable low-pass filter (30-250 Hz, 12 dB/octave)Selectable bass boost (0, 6, 12 dB at 45 Hz)Variable subsonic filter (15-50 Hz, 12 dB/octave)RCA and speaker-level inputsWired remote level control includedFuse rating: 40A x 34-gauge power and ground leads recommended —
wiring and hardware not included with amplifier12-9/16"W x 2"H x 8-1/8"D
link: link to memphis item on ebay
* * * AMPLIFIER KIT SPECIFICATIONS * * *
1 x 20 Apx 4ga Power Wire (red) with Flexible Strands, 5 m
1 x 20 Apx Ground Wire (grey) with Flexible Strands, 0.8 m
1 x RCA Stereo Audio Cable (blue), double shielded, 5 m
1 x 0.5mm^2 remote wire, 5m
1 x AFS fuseholder with 60A fuse
link: link to renegade item on amazon
* * * BASS KNOB SPECIFICATIONS * * *
link: bass knob on amazon
* * * REMOTE SWITCH SPECIFICATIONS * * *
link: switch on amazon
(4) x1 bass knob
GENERAL
SIZE 12" SUBWOOFER
Voice Coil DUAL
Sensitivity 90dB
X-MAX 33MM 1 Way
