Vizio s3851w-d4 power supply schematics
ryanbahr
Jul 21, 2018
1
Greetings everyone,
Replacing the small capacitor on my power supply board (different sound bar (S4251w-B4), same power supply board) fixed everything. It was the only capacitor to have any type of bulge, and it was a very minor bulge at that.
I'm not sure why the 5V was wired to the standby. May be a revision, or a standby by-pass. Looks like it was done post assembly though, or possibly a failure of the mask to prevent the solder from flowing.
yudhidel
Aug 3, 2018
1
Hi All,
I have a very similar issue on the exact same model. I have repeated the following behaviors multiple times, when the main board is not connected to the switching board-
1. Originally, 5v is on, but no STBY and no 24v.
2. If I connect STBY to 5v, 24v is turned on.
Noticing this, I added a switch between STBY and 5v, and connected the main logic board. However, with the main connected, I see the power LED flash and read the voltage for a moment I plug in the power, and it immediately starts dropping. After this, even if I disconnect the main and try measuring the output at switch board by itself, I don't get any readings! I discovered that if I discharge the capacitors C1 and C3, I can replicate the #1 and #2 above.
It appears certainly some component in the switch board is faulty, however not sure what to check for there. Please suggest.
https://imgur.com/a/Xwfg11B
nhc14
May 16, 2019
1
I have a VIZIO SB3851-C0 soundbar that recently stopped working (it no longer turns on). I see this is a trend. There is no C21 capacitor marked on the board however I am sure it is probably one of the same capacitors it has just been labeled differently on my model. Does anyone have any advice on any alternative solutions if swapping out the caps doesn't work?
mmmike
Jun 13, 2019
1
Thanks for the info everyone.
I was able to revive my Vizio SB4251 in 20 minutes after getting a capacitor and soldering kit on amazon
There's nothing like fixing something to make you feel great and save a ton of $$$.
Just like most, I just had to replace C21 and I was back in business. Note, it didn't even look bad (no bulging).
dkinsel2
Jun 24, 2019
1
On what board did you find the C21 capacitor? I have a different soundbar but it’s still vizio. People have had a common capacitor with all soundbars and it seems that mine is different when it comes to the PSU board and logic board.
Sin41
Nov 18, 2019
1
I have the same model. Remember saw a video on YouTube said change C15. But couldn’t find it again, not 100% sure about that.
HamRon
Jul 12, 2020
1
I have something very similar to this problem. I plug in the optical and the power cord. This led comes on dim and I press the volume and the led goes from dim to bright and one second letter it goes off and nothing come through the speaker and the only way I get to try it again is to unplug it and let it sit for quite some time but it does the exact same thing. At first I thought power board but not sure - any thoughts???
