Kabelsalat
- Jul 5, 2011
- 198
- Joined
- Jul 5, 2011
- Messages
- 198
Hi forum. Hope this question is within the scope of discussions.
Anyway - Today, there was very high humidity together with decreasing temperature (laying around or just below freezing point), and at a point, the air conditioner fan just did not start up when I started my car. After about ten minutes of driving, the fan started to run again.
Whitin the time period when the fan didn't operated, I tried many combinations and all possible fan speed settings from the air condition controller - neither did change anything, I did not managed to get the fan to start spinning again.
This led me to think there is some bad connection somewhere, probably sensible to combination of high humidity and dropping temperatures.
So I assume this may happen at later times too, and I want to prepare and have a multimeter laying around so that I may troubleshoot when it happens again.
Problem is that I cannot find any decent wiring diagram online. Those I find are either for other car models (I have this one button that toggles the fan speed setting, while the wiring diagram is for the model that have a rotational knob for fan speed - that is usual on the older model of X-trail)
That makes me having two questions:
- Does anyone have the actual wiring diagram for this car model ?
- Anyone have had similar problems and maybe have some knowledge on where i should look for weak contact points ?
Thanks in advance
Thanks in advance
