Hi all.
I am building an RC Lawnmower from scratch. It's almost finished and I am preparing to test. The motors are two 24VDC wheelchair motors. Traditionally people who build these remove the mag brakes from the motors. The motors are 250W each, and require 24VDC @ 30mA to each magbrake to disengage it. The reason they remove them (I suspect) is (1) they aren't usually needed and (2) to save on power consumption.
However, I am keeping mine installed because we have some hills in our lawn and a runaway mower seems like a bad idea. Anyways, I have an email into the supplier of the motors (SuperDroid Robots) to see if the brakes have built in flyback diodes or not.
If not, I will add my own. But I am wondering...when doing this should I put a diode across EACH motor or will just one across both suffice? The mag brakes are wired in parallel and both will be engaged simultaneously.
