Challenge - See if you can solve this simple circuit diagram
stspringer
May 10, 2019
116
Ok I have this circuit diagram that I hooked up with 12 volt battery - 2 led's with dual terminals - low beam and high beam - high beam is 3.5 watt low beam is 1.2 watt - 1157 bayonet mount. I have 2 led flashers with battery terminal and load terminal I have a SPDT switch and a DPST switch
This circuit will be used to simulate a cars "front only" running lights, turn signal - left and right - and hazard lights.
I am uploading a pic of this circuit diagram. I have another circuit diagram that fixed my first diagrams problem almost 100 percent fix. Maybe someone could explain a total 100% fix
RUNNING LIGHTS "PARKING LIGHTS" ARE ALWAYS ON IN THIS CIRCUIT
PROBLEM WITH THE FIRST DIAGRAM:
Now, this first diagram has a problem. When the turn signal is turned on, either left or right, the high beam led is hardly noticeable, very dim, will not even pass inspection as a turn signal same with the hazard lights turn them on and they are very dim hardly noticeable
I am just uploading the diagram without the partial not 100% fix. Then I would like some feedback on what you think the fix would be to make the turn signals flash at full brightness.
WHAT IS THE FIX I AM LOOKING FOR?
When the turn signals or hazard lights are on they should bling at normal speed with full brightness
not dim or hardly noticeable
Thank you for your time
Bluejets
Oct 5, 2014
7,374
If you were to draw the circuit diagram in a conventional way you would immediately see the problem associated with the dual LED in each instance.
It is this precise reason why, voltage fed auto lights in particular are switched in the negative AND in a particular sequence/arrangement.
Without going any further I am 100% certain of the correct arrangement, but hell, that would spoil your fun.;);)
stspringer
May 10, 2019
116
Correct Arrangement? You mean you would not add any components?
Bluejets
Oct 5, 2014
7,374
To begin with, you do not show any detail or link to the LED units currently used or the flasher units.
Bluejets
Oct 5, 2014
7,374
Trash the 2 element LED bulb and replace with 2 single element, perhaps add some load resistance to make the flasher work on LDE loading or replace with flasher designed to work with LEDs.
No way of knowing the internal circuit of the LED combination without hacking into one and I'm not about to do that.
I do however suspect the LED bulb / flasher combination to be the heart of the problem.( feedback in old terminology)
stspringer
May 10, 2019
116
Hello Bluejets,
I loved the video link you sent, very nice. I think I did what you mention here "perhaps add some load resistance"
I will upload my partial fix diagram now. I say partial fix because the led blinks slightly slower but the brightness is very good.
What I did was I added a diode and a 68 ohm resistor to the positive side of the led"s low beam wires
"replace with flasher designed to work with LEDs". wasn't the Amazon link I sent you a led flasher?
Tell me what you think
stspringer
May 10, 2019
116
1001 ways . . . . . . . to wire yer liddle heart out . . . . .
https://tinyurl.com/vyddkez
Thanks 73's de Edd
Check out my schematic I drew with circuits lab web software. I used 2 relays and 2 led flashers and a DPST and SPDT switches
The relay turns off pin 87a when the turn signal or hazard lights are on pin 87 is not used. I am happy
Any ideas of what I could add to employ pin 87?
  • car-cuircuit-turn-signal-hazard_2.pdf
stspringer
May 10, 2019
116
Hello Bluejets,
