I have just started using the green circuit boards (the ones with the holds and solder rings).
I notice that there is lettering (the alphabet) printed alongside one edge of the board. When i flip the board, there is also the alphabet, but it is in reverse order from the other side of the board.
Why wouldn't they make the letters match up on either side of the board. that way, if you identified a pin in column T, hole 1, you should be able to flip the board over and trace that same pin to T 1 on that side as well. But Nooooo....
Why would they not print the same order on both sides so that you can easily trace where things are?
