Satellite receiver Power supply higher voltages output
pharaon
Oct 28, 2014
458
This power supply output voltages is higher than it should be, what could be the cause
Standard voltage actual voltage
23V = 32V
12V = 18.5V
3V = 7 V
Next 3V = unstable 0.5 to 1.6 V
5 V = unstable 6.8V to 7V
Cirkit
Oct 28, 2015
156
Try measuring those voltages again with your black probe on the respective GND pins.
Bluejets
Oct 5, 2014
7,374
Perhaps but it might be different if you use the black probe on the reference "GND" that is adjacent to each 3v3, 5v and 12v etc.
23v is the far right, not the second as you have marked.
Which meter range are you using?
Edit...Cirkit...beat me by .......that much) :)
Bluejets
Oct 5, 2014
7,374
Meter on dc range..?
Meter tests ok..?
unusual for any reading to go higher than normal (within tolerances)
Input voltage/frequency match input requirements..?
Board looks to have been pretty warm around the switcher ic and associated bits.
pharaon
Oct 28, 2014
458
yes
Meter tests ok..?
yes
yes
although it's working and there's an output voltage
i need to know the cause of the higher output voltage, cause it cause the receiver to hang up while working or give me "searching for signal" for some channels
Cirkit
Oct 28, 2015
156
What voltage do you measure at IC1? Does the capacitor next to it have a domed top - hard to tell from the photo angle?
Have you tested all the output diodes?
Bluejets
Oct 5, 2014
7,374
Look for details on the switcher (5L0365R) which should bring up a data sheet and a load of schematics.
Perhaps not exactly the same as your board but enough to get an idea of the layout.
I found a couple of videos but mostly Russian/Vietnamese so not much help but it does show it is a fairly common type of board.
Cirkit
Oct 28, 2015
156
at what pic exactly should i do the measurement
If IC1 is a KA431 or similar, look at the values of the two resistors closest to it. You should be able to work out the set voltage.
Cirkit
Oct 28, 2015
156
how to tell if it's?
Can you read the markings off the flat side of the component?
You will need to trace the resistors that form a potential divider for that IC. Watch the video above, you are looking for the equivalent to R204 and R205 connected in the same way to IC1 on your board.
Cirkit
Oct 28, 2015
156
Not the controller IC. The small 3-pin component marked IC1 next to it.
pharaon
Oct 28, 2014
458
i also have tested the big cap 47uf 400V and it gave me 36uf, is that acceptable? and can it cause such higher voltage in the output ?
Cirkit
Oct 28, 2015
156
Now find the two resistors that form the potential divider for that part.
How did you measure the capacitor? Was it discharged first, in-circuit?
