To Short or not to Short- that is the question
SparkyCal
Mar 11, 2020
863
Can someone help me interpret this schematic below
My question relates to Pins 2, 3 and 4 on the 555 Timer.
Does this schematic require that Pin2 be shorted to Pin 3 and pin 3 be shorted to Pin 4?
I am thinking not but I am not sure.
Thank-you
dave9
Mar 5, 2017
1,191
No, if connected together there is a round dot joining them.
Nanren888
Nov 8, 2015
622
In this style of diagram, only dotted crossovers are connections.
BTW: the unlabeled input on the flipflop [from 55 pin 3, to "tact" momentary pressbutton] is probably labeled "CLK" or clock on the data, pin-out.
SparkyCal
Mar 11, 2020
863
Thanks guys. Just learning about flip flops. I breadboarded this tonight but it failed. Likley because it is not well labeled in certain spots. I'll try what you suggested Naren888
SparkyCal
Mar 11, 2020
863
I need to re-do this. I did it while tired and rushed and that probably accounts for thre failure. if it fails again, when i re-do it, i will post it
Thank-you
bertus
3,852
Hello,
You will encounter different types of schematics.
These pictures show the difference between the old method and the new method for drawing a schematic crossing:
This can be confusing, so take a good look wich method is used.
Bertus
