Tha fios agaibh
- Aug 11, 2014
- 2,253
- Joined
- Aug 11, 2014
- Messages
- 2,253
My Daughter bought some led strip lights for her room.
Problem is, they came with a controller that has two plugs designed to independently feed each of the 2 spools of strip lights.
She wasn't happy she couldn't have a long continuous strip of lights so I spliced the 2nd spool into the first.
It does work, except the colors of the added length doesn't always match the first.
Blue is the same, some colors only slightly mismatched, but red doesn't work at all.
I was under the impression the strip was just parallel R,G,B leds with limiting resistors and color were derived by a pwm stream that fired the leds?
Why isn't the color pattern matching?
I imagine it's because the additional load. But even if it was overloading the power supply I'd still expect the same colors along the entire length.
