ardino code for Two color LED to PIC18F45K80
bertus
3,877
Then the green is probably blown.
What happens when you connect the left pin to + 5 Volts via the resistor and the right pin to ground?
Bertus
Djsarkar
Jul 27, 2020
46
Bertus
Previously red was turning on, now it is not turning on. It is very sad to inform that both the leds has been damaged.
Bertus thanks for helping me
bertus
3,877
Where did you buy the module?
Perhaps you can buy some bi-color 3 pin led and replace it.
Bertus
hexreader
Apr 21, 2011
139
Hard to be sure, but from your earlier picture, it looks as though you are using a 1000 Ohm resistor and a 56 Ohm resistor
1000 Ohms = good
56 Ohms = burnt out LED
Djsarkar
Jul 27, 2020
46
Bertus
I bought a 37 into 1 sensor kit from aliexpress long time back. I did not find any document user manual. Sure I will replace Led.
I have other sensor, they still have to be tested. I will test any one of them
