Hp 2035 monitor Check the Signal Cable
pharaon
Oct 28, 2014
458
of-course i tried it on different computers with different cables and still the same issue which made me believe it's a hardware issue in the monitor it self
i uploaded some pictures , hope any one can help me fix it
what should i check first
[MOD note - deleted excess photo double-ups]
Bluejets
Oct 5, 2014
7,374
Much better to describe the fault instead of what you think is what needs fixing.
pharaon
Oct 28, 2014
458
the fault is that it always show me no single, cable changed, PC changed, made sure the socket connector is fine
what else to check to fix that error
Bluejets
Oct 5, 2014
7,374
Have you traced all the cabling to the board for any breaks..?
Martaine2005
May 12, 2015
5,315
The FBI must feel like this when trying to get information from a suspect!.
In the mean time, does it have any indication of power?, back light?LED?, noise?.
Have you checked the fuses on the board and in the plug (if it has one)?.
Martin
bertus
3,868
Hello,
Does the monitor have more inputs?
It seems to have the following inputs : Composite, DVI-I, S-Video, VGA (D-Sub).
Then try an other input and see if that is working.
Bertus
pharaon
Oct 28, 2014
458
first thing i did and all was good
the screen turn on and show on the screen that Error message then go to sleep mode
tow on the power circuit and they are fine
will try that
pharaon
Oct 28, 2014
458
i did and still the same, the monitor keep black for couple of seconds and on screen message " monitor will sleep" then goes black again as just before it start displaying picture but it remain black for couple of seconds the the message of sleeping again and that keep going
Martaine2005
May 12, 2015
5,315
It seems to have power or at least standby power.
I would check all inter-connect cables to both boards. Unplug and reseat. Check for cracked or dry solder joints. Check those cables for continuity too.
Your photos are too fuzzy to enlarge.
Can you see a connector that may have voltages written on the silk screen?. If so, check those voltages.
Martin
pharaon
Oct 28, 2014
458
Martaine2005
May 12, 2015
5,315
On the PCB, there are reference designators. R32, C14, F2 etc. Not necessarily the numbers I wrote.
Any lettering, numbering or symbols are silk screeen printed onto the PCB.
You might have a connector with eg: 5V+, 12V+, 28V+, 0V.
They are voltages on those connections and therefore those rails.
Martin
pharaon
Oct 28, 2014
458
checked and all seems ok
there's none
got new set of photos with decent resolution ,you can click on the image to open it in it's normal size
1. How old is this unit?
2. Have you had it from new?
3. When did it start exhibiting this fault?
4. Did the fault suddenly appear, or did you have increasing difficulty with the monitor before it finally failed?
I have seen similar problems caused by power supply issues in monitors. However these faults often develop over time. They are also faults that tend to occur in older equipment, or equipment that has been continuously powered on for years.
I would be checking the ESR of the capacitors in the power supply. I've taken a look at your photos and none of the capacitors look stereotypically faulty.
