alex ezorsky-lie
- Aug 27, 2015
- 27
- Joined
- Aug 27, 2015
- Messages
- 27
My goal is to build a dimmable led light of 75-100w in the cheapest and easiest way possible for video lighting.
As an experiment I bought this $30 75watt AC bulb from amazon. Its crazy bright but of course not dimmable (it flickers if attempted). My thought was that I could add a dimmer to the built in driver. Also if I could add an optional dc input that would be awesome too.
I took it apart and tested the output voltage and current leading to the LED’s and its 75v and .83 amps. Being that I am a novice with real circuitry I am at a loss as to where in this little ac-dc driver I could add a dimmer with the least complexity. My instinct is to do it on the output leads since thats the only part I understand but considering the board itself is already regulating voltage I figured there might be a more elegant solution. Also not sure how or where I could put dc input leads without frying things.
Thanks!
(the little plug is for the fan)
Thanks!
