Really need help!
Harald Kapp
14,271
Hmmmm, does it work directly from the power supply (no controller in between)?
Harald Kapp
14,271
Looks like the motor draws too much current. The motor is possibly not rated for 12 V but less.
Try a 6 V lamp in series with the motor.
Or even the12 V lamp you just used.
Harald Kapp
14,271
yes it works directly from the power supply
So the issue seems to be the power delivery from the controller.
Do you have a multimeter to measure the current the motor draws when connected directly to the power supply (no lamp)?
james.50cal
Sep 12, 2014
56
no I dont have one of those. If I run them from the controller at the same time neither the motor or light will work
Harald Kapp
14,271
Lamp and motor connected in series? Not in parallel.
Series means: wire from controller to one pin of the lamp, from the second pin of the lamp to the motor, from the other pin of the motor back to the controller. At least the light should work then.
james.50cal
Sep 12, 2014
56
Thanks for all of your help I really appreciate it, you are a clever man! I decided to buy a rotisserie motor instead of messing about getting a new 12v motor.
