- Joined
- Nov 17, 2011
- Messages
- 14,317
If it works from the battery or directly from the power supply, it is supposed to work from the controller, too.but could the motor be a higher voltage?
That is one option, but try the lamp in series first. A 12 V lamp will suffice for the test, albeit the motor will be rather slow.do you think I should just buy a new 12v DC motor
So the issue seems to be the power delivery from the controller.yes it works directly from the power supply
No, from the controller.so run the lamp and motor directly from the power supply?
Lamp and motor connected in series? Not in parallel.If I run them from the controller at the same time neither the motor or light will work
