Hi all,
I'm really just after an understanding check here. For my project (Model Railway in the garden), to prevent me having to run 240v all around the garden, i'm planning on putting the 240v/220v to 12v transformers in a shed, keeping the dangerous stuff out of the weather.
I want to minimise the voltage drop over the distance, so i've been investigating what cables I have.
According to https://en.wikipedia.org/wiki/Voltage_drop the simplest way to reduce voltage drop is to increase the size of the conductor.
The standard wire I use is 7/0.2mm. I also have 16/0.2mm and some single core .5mm.
Its my understanding that simply increasing the number of strands of the same size, (for instance using the 16/0.2 rather than the 7/0.2) won't decrease the voltage drop, but using the single core .5mm will have a lower drop. I believe this is because the 0.2 has the same resistance for the same length regardless of the number of strands.
The 7/0.2mm and the single core .5mm have roughly the same diameter overall.
Am I correct in my thinking the the single core .5mm is superior in terms of voltage drop, or should I use the 16/0.2mm for 'best performance'?
N.b. I don't want to add additional circuitry to boost the voltage etc, as I'd prefer to keep it simple.
TIA,
Steve
TIA,
Steve
