Its PC ATX PSU, the power switch only turns on mains voltage not the PSU. I've check the cable and there is no jumper wire on the 24 pins connector and also all the voltages are ok. Even went and test the PSU with a motherboard and it boots and works fine.
I've already removed the PCB (discharged the high voltage capacitors) and did a small inspection (mostly visual), remove some dust but didn't find any damaged components, at least nothing too obvious.
I had the idea that measuring the green wire to ground i would have something about 5v but I'm getting around half that (2.4v). Could be a damaged resistor or something?
i know that a jumper wire from green to ground will turn the unit on. check if there is a short from green wire to ground with your multimeter on diode mode
I've check the cable and there is no jumper wire on the 24 pins connector and also the voltages are all ok. Even went and test the PSU with a motherboard and it boots and works fine.
Could the capacitor be damaged and acting as a resistor to ground?
I've measured the impedance between the green wire (PS_ON) to ground (with the PSU unplugged) and I've got 23.9MΩ
you mentioned in your previous post that you recorded 2.4v at PS_ON. Do you still get that reading?. Concerning the capacitor you can remove it and see if the problem still persists. Also check for any shorts on the transistors and diodes.
I've already tested the diodes and other semiconductors for simple failures, like shorts or opens, and found nothing obvious...
Anyways, I will recheck the voltages for inconsistencies (following the 1st, 2nd and 3rd commandments: Thou shall always check voltages), then the capacitor to ground and afterwards other componentes around that circuit... Will post any finds.
I've done more testing, having in consideration all the suggestions above and this is what I came up:
Effectively all voltages where being correctly outputted as soo as the power supply was connected to mains
The green wire (PS_ON - power supply on) to ground was about 2.5v
The gray wire (PG - power good) to ground was 0v
All voltages where correctly reported to the WT7517 chip and the PGI (power good input) was about 2.5V and the PGO (power good output) was 0v
When i short the green wire (PS_ON) the PG output starts reporting the correct 5v - the WT7517 chip validades all power rails
Traced the optocoupler controlled by the chip, to indicate the primary side to start the main power rails, and it was good and correctly flipping the power on/off states when shorting/opening the PS_ON line
On the primary side, tracked the power state circuit and found a PNP Epitaxial Transistor (A928A) that was shorted on all terminals
Having found that, I did what we should do in this situations. Having not found a direct equivalent transistor on my transistors stash, impatiently, tried to use a "indirect" equivalent transistor that also did not worked (wasn't Epitaxial and didn't noticed that was EBC instead of ECB) and maybe broken something else on the primary because even putting back the old transistor the PSU did not start again...
Anyways... I've ordered the correct transistor and when it arrives ill be diagnosing the primary side for any more faults since i can probably assume the secondary side is completely fine.
Lesson learned...
I agree. Normally it's the 5V section that is used as standby. Ive never seen an ATX PSU use lower than that. I suspect that some capacitor may have dried out and causes short circuit or low resistance path.
