What type li-ion battery use in cordless power tool protected or unprotected
mrel
Jul 2, 2008
115
What kind battery is use in cordless power tool, the battery look like 18650 battery.
Are they 18650 battery unprotected type battery or protected type?
Are there high drain battery?
mrel
davenn
14,479
mrel
That is unanswerable with the little info you have given
It would depend on the manufacturer to what they chose to use
Externet
Aug 24, 2009
943
The 18650 is not a battery, it is a lithium cell that when using multiple wired in a pack become a battery. A lithium battery is usually protected; has circuitry that prevents mishaps and abuse in charging and discharging. When such circuitry is implemented, cells do not need to be individually protected also.
Individual cells that do not work as part of a battery pack can be of the protected type. There is both types of 18650 cells. High drain is achieved by connecting several cells in series/parallel.
----> https://lygte-info.dk/info/battery protection UK.html
dave9
Mar 5, 2017
1,191
Manufacturers of tools with user-replaceable individual cells, could go either way, placing the burden on the owner to use a protected cell, or building in a protection circuit into the tool.
Tools that don't have user-replaceable individual cells, instead integrated into a battery housing, generally use unprotected cells, but with a BMS circuit in series that provides for overdischarge protection, overcharge protection, balance charging, and often thermal protection.
If you gave us a bit more context of why you are asking or a link to a particular tool, it would be easier to determine.
Harald Kapp
14,289
A common misnomer. I bet 99.9 % of all people use battery when they really mean a single cell. I gave up on this discussion a long time ago ;)
Kiwi
Jan 28, 2013
505
Is that a bit like calling vacuum cleaners a hoover?
Harald Kapp
14,289
No, it isn't.
When you call a vacuum cleaner a Hoover you use a brand name as a generic name for a class of devices. Same goes for e.g. Kleenex and others.
But a cell and a battery are technically different. A battery is made of 2 or more cells.
But a discussion will not lead anywhere (other than filling up the disks on the server). Colloquially "battery" is used for both. Plus I doubt that one could make the average user make aware of the subtle difference. Both supply DC power.
