I want to brighten my LCD, its specification says 300cd/m², I want to brighten it to 350cd/m²-400cd/m².
How to adjust the backlight of the LCD?
Does this 5-pin cable lead to the backlight?
I am attaching a close-up view of this part via attachment.The backlight is probably powered by this section:
Does this 5-pin cable lead to the backlight? If so please provide a close up image of this section so we can identify components. It may be able to change the LED current by changing a resistor here. Are you prepared for some SMD soldering here?
Note that increasing the brightness may reduce the lifetime of the backlight/display due to higher thermal stress.
Yes, it's a touch screen.Does this LCD have a touchscreen ?
Awaiting the OP's response to my Q to confirm, but ....
But i suspect that 5 pin cable is most like for a touchscreen
Possibly.But i suspect that 5 pin cable is most like for a touchscreen
