Hi everyone,
I am dangerously under-qualified, so please be understanding if I'm way off base...
The Story:
I'm doing an automotive project where, among other things, I'm changing the transmission in a Toyota 4x4 from automatic to manual. Its part of an engine swap, so I'm building a wiring loom, and adding a circuit will be very easy.
The manual transmission I have used a rotating cable to tell the instrument cluster the speed of the vehicle, but the vehicle I'm putting it into uses an electronic signal generated from a Vehicle Speed
Sensor (VSS) mounted on the transmission. I found a VSS from another vehicle that physically fits that will convert the rotating mechanical output to an electrical signal. The VSS I have outputs a switched ground signal, but the vehicles instrument cluster needs a switched +12v signal. I want to design a circuit that will go between the cluster and sensor to convert the signal polarity. So to clarify, VSS I have is powered, (It has +12v and ground (-) wire going to it, as well as a signal output... so 3 wires.) The output it generates alternates between open and ground 4 times per rotation. I need to convert that signal to alternate between open and +12v 4 times per rotation instead.
The Circuit:
The circuit I have come up with uses an IFR9Z30 and a 10k resistor; I have drawn a very tiny circuit diagram and attached for a visual reference with the questionable portions in gray.
+12v goes to the source pin. (This can climb as high as 14.5v when the alternator is charging, for those who are not familiar with Automotive.) The output of the VSS goes to the gate. The 10k resistor goes between the source and gate to keep the MOSFET off when the gate signal is open. The drain pin goes to the instrument cluster as the new signal.
The Questions:
Does my circuit make sense, or is it totally wrong or missing something?
Is my component selection ok? I'm especially concerned about the 10k resistor, but would appreciate confirmation on my MOSFET selection as well.
I'm not sure how the cluster works, but there's a good chance that it's inductive; should I add a schottky diode between drain and +12v to be safe? (in gray on the diagram)
I also see some circuit diagrams have a resistor from drain to ground; do I need that? If so, what value resistor would be appropriate? (I have lots of 10k resistors... will that work?) (also in gray on the diagram)
Thank you for taking the time to read my long post, and I appreciate any feedback or suggestions anyone can provide.
The Story:
The Circuit:
The Questions:
