Step 1. Does anyone know where I can find laminated soft boilerplate steel core to buy in Europe?. The bigger the better as I plan to wind the primary and secondary coil my self in various sizes for several use cases.
I do have a 3d printer and can print with non conductive magnetic (iron filled) pla filament once it arrives. Could I simply print the transformer core and have acceptable results?
Step 2. The first use case would be to charge a LifePO4 3.2V cell with 3.6525V at 140 amps to see if it can (test if the cell is up to specs)
As source I have 16 amp 228VAC single phase.
If I give the primary coil 380 winds (760 turns) with 0.4mm enameled copper wire
and the secondary coil 6 winds (12 turns) with 5x1mm (with the ends soldered together) enameled copper wire. Is my math correct in where I should get around 3.65V output minus some losses?
I realize I'll need a full bridge rectifier in between the transformer and the battery cell but if I get stuck there I'll create a separate thread as to focus the topics.
