I am constructing a class D audio amp. The plans I have are using am LM393 dual comparator for mixing audio signal with high freq triangle wave. The response time of the 393 is 1.5μs. I suspect that if the response time is this lengthy, slew rate also is lengthy. My triangle wave is at 200KHz, time period 5μs. 1.5μs is a big chunk out of 2.5μs transition. I have 2 - AD811 on hand that produce my 200 KHz as an output very nicely. The AD811 were a bit pricey. Also it would be convenient to have dual amps in one package. Any suggestions as to comparator choice. Their outputs will drive an IR2110 MOSFET driver.
