Difficulty finding the appropriate resistor with power calculation
t101
Jul 10, 2022
24
What is missing is a schematic showing the power supply voltage and the forward voltages and wiring of the "multiplicity" of LEDs,.
I would have posted this initially.
t101
Jul 10, 2022
24
Really? Then I strongly suggest you be VERY careful while you work on it!
Because: If the designer of your "setup" was really willing to waste 15V across what's nothing but a heat-producing ballast resistor, then the total supply voltage across resistor plus series LED chain can be expected to total well above 100V, creating an obviously dangerous shock hazard.
Otherwise they're a very poor designer to create such an inefficient circuit, and the "setup" can be expected to be dangerous just from being a lousy design.
Then please help me change the voltage to something more appropriate and simple fitting a ballast resistor.
CircutScoper
Mar 29, 2022
300
Why not connect all your LEDs in a single series string and power them all from a single resistor, thus drawing only half the current? Sketch attached.
By the way, the photo is of a beautiful red shouldered hawk that kindly paid me a visit one day outside my office window -- not an owl.
Audioguru
Sep 24, 2016
3,656
Guess what? Red LEDs are not 1.23V. Instead they are 1.8V to 2.1V when at about 15mA.
CircutScoper
Mar 29, 2022
300
Even more efficient would be a 6V supply.
t101
Jul 10, 2022
24
View attachment 55778 View attachment 55781
What a magnificent alpha predator. I had the chance to meet one in Georgia when it dove in and lifted a rabbit off of the road in front of me.
Series would be easier but I need the parallel for setup purposes.
CircutScoper
Mar 29, 2022
300
Then running them from a 5V supply with 180 Ohm resistors would save 2/3rds of the energy and 80% of the wasted heat (assuming equal power supply efficiencies).
t101
Jul 10, 2022
24
The resistor in that case will be in series with the LED/LEDs so their voltage drop must be subtracted first.
i.e. if you have 2 red LEDs in series with your resistor, you must first subtract 2 x 1.7v (or there abouts) first.
Remainder is the voltage that will appear across the resistor.
If 12v supply, then 12 -(2 x 1.7v = 3.4v) = 8.6v.
You then need to calculate the resistor at 8.6v divided by whatever current through the LEDs (say 20mA)
So resistor is 8.6/0.20 = 430R.
As that is not a standard size, then go to 470R, you won't be able to see the difference.
Then the watage would be 8.6 (v) x 0.02 (A) = 0.172W .....so 1/4w resistor.
Maybe a picture will help. What is the voltage across the resistor? Hint: You'll never know until you measure it with an actual voltmeter.
Ok so I've reduced the voltage to 5v and the current being drawn is
33.6 ma. The LEDs are getting sufficient current. What is the max current I should look for given a 5V supply in this circuit? I came across one PS that had 5V with 2000ma obviously too much. What combo of V and current would meet the needs of this circuit while being safe especially?
CircutScoper
Mar 29, 2022
300
Ok so I've reduced the voltage to 5v and the current is being drawn is
33.6 ma. The LEDs are getting sufficient current. What is the max current I should look for given a 5V supply? I came across one PS that had 5V with 2000ma.
I don't understand your question about "max current." Sounds like something to consult the LED datasheet about -- not the PS's.
t101
Jul 10, 2022
24
No, sorry max current of the power supply for this circuit. As you pointed out my 15V 300-400ma PS was seriously flawed. So what instead?
Thanks
Audioguru
Sep 24, 2016
3,656
Nobody needs a low current AC-DC power supply so they are not made and not available.
Years ago some big and heavy 6V/300mA AC-DC power supplies were made expensively with a transformer.
Today millions of 5V/2000mA AC-DC power supplies are made inexpensively for charging a phone. I bought a tiny one
Look here:
CircutScoper
Mar 29, 2022
300
Thanks
It was a question of voltage and efficiency. Not current.
>80% of the voltage, and therefore power, of your 15V supply was being wasted in the ballast resistor. By contrast "only" 50% of the power of your 5V PS is going down the drain. You tripled your circuit's efficiency.
