help fixing audio amplifier no sound out
pharaon
Oct 28, 2014
458
it's USB reader and FM radio as well YT-326A
no sound out
it have TDA7057AQ IC
how can i check if IC TDA7057AQ is malfunction with multimeter?
Martaine2005
May 12, 2015
5,314
I would suggest a good cleaning of the board and it looks like the solder needs a good going over as well. Then see what is and is not working.
Martin
Delta Prime
Jul 29, 2020
2,993
it's USB reader
I'll let that one go!
Looks to me like a parts board.
Reference data sheet TDA7057AQ provided below.
Check supply voltage Vp, pin# 4
For the dual operational amplifier 4558
Check supply voltage VCC+, pin# 8
  • TDA7057AQ.PDF
  • GP4558.PDF
bertus
3,868
Hello,
@pharaon , It would be nice if you could share the solution.
That way others with a similar problem could be helped too.
Bertus
73's de Edd
Aug 21, 2015
3,730
Is this a flood recovery item and is that being deposited silt on top side of the board and . . . . . .ME TOO ! . . . . .WHAT FIXED IT ?
