Braeden Hamson
- Feb 18, 2016
- 240
- Joined
- Feb 18, 2016
- Messages
- 240
I am in the process of building a ~300A power supply with the intention of testing fuses at 300-70A over the course of 0.01 seconds to 60 seconds. So far I have an appropriate heatsink, 1 AWG conductors, and 300A capable contactor. I'm confident that all of my supporting elements are capable of handling the current. My issue is creating the variable current supply. I've tried using 5 mosfets that were each rated to 222A each. I was varying the gate voltage to attempt keep the mosfets in saturation and manage the current. However, it seems that at some point, perhaps when the fuse blows, the mosfets fail. I've found that there is no resistance between gate and source on any of the mosfets (after failure). My power source is a 12V car battery with 600 CCA.
My question is, is this the correct way to go about this circuit? Should I use BJTs, IGBTs, or something else? I'd like to have roughly 5A of resolution.
I'm familiar with mosfet current mirror circuits, however I'm unsure how to determine the length and width of the mosfet silicon in order to figure out the current gain of the system.
I understand this is a dangerous device and I'm taking appropriate precautions.
