I have a "Smart Management Module", made by Generac, that has died, and I am trying to see if I can fix it. This unit's purpose is to monitor, I believe, the frequency of the power coming into it and if the frequency falls below a certain level, telling the module that the generator is being overtaxed, it cuts out the load that is connected to the SMM by opening a relay/contractor. In this case the load is my upstairs air handler.
The PCB has the a short in it. The PCB is fed by two inputs, at 240V, and has one output, to a relay that cuts the power going though it, if necessary.
Initially I found that a resistor and a PTC were cooked on the board, as I observed black soot around these components. I did manage to identify these components and replaced them, with the hope that I had just experienced a power surge at some point and those components sacrificed themselves to protect the rest of the board. This was not the case. I reinstalled the board and as as I powered it up I heard a pop and the resistor and PTC seemed to get fried.
I have attempted troubleshooting with my limited knowledge, under the impression that logic chips seldom go bad and other components such as capacitors are likely to fail first. I have not been able to identify all of the components on the board so that limits my ability to research diagnosis, hence I am here.
Looking at the overwall board, I see some brown areas on the underside, and they seem to be under resistor mounts and what I am guessing is a transformer. On the top, none of these compents have obvious signs of failure.
The large capacitor on the board, relative to the other possible caps, is a 10mf, 450v unit that looks like some soot beside it, so I replaced it even though it tested the same as the new one. It was not bloated or showing any other signs of failure. This was after replacing and popping the new resistor and PTC.
Since I do not have an AC power supply that I can limit the current on, I replaced the resistor and PTC again then connected my DC power supply feeding 30v, max 2A, into the board. The toridoral inductor, the PTC, and the resistor got quite warm. I noticed nothing else getting warm, and the power LED did not light up. I do not know if this tells me anything useful since feeding DC into an AC circuit may make components act differently than with AC.
I would like some hand holding on what to check and how to check the individual components.
Thanks,
Chris
Thanks,
Chris
