I made a solar pool heater, but want to regulate the outlet flow. If it just flows unregulated, the water does not get warm enough.It needs more time in the sun before going into the pool. I want to install a sprinkler valve controlled by a timer circuit that will open at 3, 4 or 5 minute intervals and remaining open for approx 1 minute on time before shutting off. This will allow the water to absorb sunlight and heat up before discharging into the pool, essentially cycling on and off throughout the day. Hope this makes sense ! Can you give me some schematics for such a device. I can make it fixed time amount or adjustable. Much appreciated !! Thanks
