Hi,
I'm working on repairing power electronics training boards. This training board has 3 power sources, 1-ph 13V AC, 3-ph 11V AC and +15/-15 and +10/-10 DC.
This is the main training board scheme -> on the left section of the board, the power supply blocks:
1. F1 and F2 are the AC fuses, so the AC blocks are protected.
2. The DC block as it's clear, not protected and the DC lines and direct connected to the parts of the board that are working with DC voltage.
The AC sections are protected with fuses and they are working OK, any mistake in the wiring, the fuse breaks and I just have to replace it and problem solved.
But the real problem is the DC section isn't protected against short circuit mistakes and that causes different problems; like, broken main voltage regulators, other ICs powered with the DC voltages, burnt resistors, transistors, etc.
Here are some pictures of burnt components because of wiring mistakes:
This is the DC schematic circuit:
My question now, is that what can I do to protect these DC lines ? I thought of using ploy fuses, where I can cut the DC voltage line and put a poly fuse in series with the +ve voltage line, would that work ?
