Macknumber9
- Jun 7, 2023
- 24
- Joined
- Jun 7, 2023
- Messages
- 24
I am troubleshooting a relay that i think is bad on a circuit board for a wine cooler....
I am getting 120 vac to one leg of the load but not getting 120 vac to other leg which gives power to the compressor...
I am trying to diagnose if the relay itself is getting the correct voltage on the coil side or not before I determine that the relay is at fault.
I am reading 12vdc on one side and 6vdc on the other side. Are both legs of the coil supposed to read same voltage or should one side read ground voltage?
