Thanks for the quick reply My customer wants a way to determine whenever a person enters this freezer that goes down to -20 and does not exit in 5 minutes an alarm would be triggered and others notified in the plant. Thanks for your suggestionsLooking for something that would cause an alarm if a person stays in a freezer for over 5 minutes. All I need is a relay closure or open. Thanks
power source in plant is 220 or 110 and they can install that wherever we want it.I have a suggestion go with that next time full description I left my crystal ball at home anything else?
Would you like a DIY or you want to purchase it off the shelf you want it module so you can just plug and play what power source in your plant
Where would you like it located outside the freezer or inside the freezer think about it!
Throw everything that you got at me this way I can give you an in-depth recommendation.
Basically I'm doing your job for you but that's okay we don't want anybody to get hurt
Op obviously referring to commercial cold room arrangement .May I ask what are the individuals going be doing inside the freezer
There must be safety inspections for the company to staying compliance mandated by a regulatory commission and along with proper training for employees concerning safety protocols.The whole idea is beyond electronics monitoring as they (electronics) themselves create an additional situation
Not if it is not an approved so-called "safety implementation".The added safety implementation of electronic detection shows diligence on behalf of the company for the well-being of their employees.
Not changing the rules the laws.Personell would under your explanation become complacent and reliant on an electronic device which (as yet...possibly never will) has no compliance
Those units are proven , manufactured specifically for walk-in commercial freezers ,operate below minus 40° CI think you need to install a PIR sensor inside the freezer.
