I am attempting to repair a Yorkville KW100 (schematic attached). When I plug a music source into the return input which goes directly to the power amplifer section of the unit I get a clear loud musical output from the speaker. However when I plug the same music source into input channel one I get no output, and when I plug the same music source into channel two I get a very quiet output with the volume control for channel two turned up all the way. It is a weak signal but it is not distorted. I have replaced the op amp for channel two (U1 in the schematic) and tested the volume control for channel to be sure it is not faulty. I am a beginner in electronics repair and would appreciate any insights as to why I am getting such a weak signal from the pre amp into the power amp.
